Running the Tube to the water--be careful
Don't know if this could be an issue, but on my 9.8 merc 2 cycle, I noticed that the engine ran rough, lost some power, when my crew bunched up in the back of the cockpit on the way into the dock. Realized that in a following sea, the upper exhaust port on my merc could dunk into the water because of the combination of aft heavy balance and the water welling up. Problem immediately went away when I moved the crew forward, and also by keeping my v-berth water tank full. Bottom line: you might see engine efficiency go way down if you try to run a tube from the exhaust port into the water and thereby introduce backpressure. Comments?
