JurisG,
There is a lengthy discussion of bilge pumps over in this thread:
http://www.pearsonariel.org/discussi...ght=bilge+pump
When I had A#3, there was an access plate under sink cabinetry that led to the way-back-way-deep part of the bilge. I mounted a small bilge pump on a piece of angle-aluminum and stuck it in the hole. That way I could get the darned thing out when it was time ti fix it.
However, there are some important differences:
1.You have an engine where I had an empty space (I had the O/B version)
2.You likely don't have any kind of panel, but also can't likely see what's back there because the engine is in the way.
You need a very small, very flexible 6 year old gymnast to climb back there and tell you what's going on.
Or put the bilge pump in the best place you can and call it a day!
