the fluoroelastomer caper
This is really for the deep DIYs amongst us and it's a bit long winded - but it's about IMCO important stuff:
338 is having her OB well totally altered. Serious thought has been given to using the space on either side of the hole for builtin, and twice the capacity, tanks. Finding info on 'home' building gas tanks is practically non-existent. There are any number of talking heads that tell you not to do it, there is no comparative information. For some, this represents a challenge. 338 is very close to having a couple of quarter tanks builtin.
It is generally conceded that vinylester, an epoxy modified polyester, is best for modern modified gasolines. I haven't experienced it yet - literature suggests the stuff is finikky as to moisture & temperature and set failures are not uncommon. It's probably best for broad layups rather that small intensive tank laminations.
My epoxy retailer suggests using his extrahard epoxy for my tanks, pointing out that the HarleyDavidson crowd use it for sloshing their hoggtanks - with no complaints. All fix-leak sloshes are epoxy, I think. Stopping to catch one's breath is, for me, one of epoxy's best attributes I can remember the intense paranoia with poly as it would suddenly gel mid-stroke.
Another concern with gasoline is what rubber to use for gaskets and rings. This led me to the McMaster Carr online catalog where I got edjucated as to what materials are generally available. There is a single expensive rubber standout called Viton (by Dupont Dow.)
That took me to the Minnesota Rubber site for further study on rubber polymers. And confirmation that flurocarbon (FKM) is the only synthetic rubber product for gasoline application. I don't know what the choices are at yer local autoparts store but modern gasoline mixtures eats most rubber, and most epoxy, befor lunch.
Paul Oman at epoxyproducts,com says it turns epoxy into jelly. 338 can get some real nice tanks with epoxy and matt started. Then I could line the inside with extra-hard or vinylester & matt...What else is there....? my brain's been halfmast of late.
Type in "fluroelastomer liquid". Of course, what else...? Email the first likely hit - explain my need and application - and fill out the 'company' form. Half na hour later get a phonecall. After 10 minutes of cirling we discover that PL6032 may be the perfect solution for my application. And the perfect solution (no pun intended) for sealing all sorts of tired and leaking fuel tanks. We talking here of a coating that bonds to nearly everything and is IMPERVIOUS to gas, ozone sunlight UV salt spray oil gasoline hydrolic fluids bases hydrocarbon solvents and acids. Used in industry but never the retail marine market. He thinks my lining my tanks with his stuff is a great idea! It is pricey, but it's a coating. Has to be shipped hazmat. I'm getting some miniature free samples. Turns out I've been talking with the owner of the company!
The DupontDow site for Viton cautions against compeditors saying things like "as good as.." or "contains similar.." www.pelseal.com uses the genuine ingredient (but as yet untested in my case or so far as I went with the conversation on inplace used tanks.) Anybody want a salesman job - be a boat show booth gypsy? Man, this looks so good to me! ...........Input please
Right now can't see the down side. Shore like to hear yer opinions.....
LEAK - FLASH - BOOM - etc
Fuels, such as gasoline, are scarry stuff to me. Why not go with ss tanks? Then all you would need is that special synthetic rubber for gaskets and fuel lines. Plastic is probably cheaper, but . .
