Outboard Well & Gas Fumes
My 8 hp, two-str oke OMC outboard runs in the well of my commander. After running a while we get gasoline fumes below.
I don't detect any leaks from the line or engine, but it is a two-stroke... Even if it were leaking gas into the well, how would they be getting below?
I have epoxy sealed the worn areas in the well, and all the joints between the sole, bulkhead, hull and well. Also I sealed with epoxy the aft wall of the well where the upper exhaust sprays.
What should my next move should be? Replace my fuel line, Remove the sole of the well to rebuild/seal, Barrier coat my hull (maybe the gasoline slick on the water is soaking through)?
(BTW, with the top closed and cockpit hatch open it does not suffocate when run at high speeds, but that's another thread.)
Regards,
David
commander #92, la saladita
