Aging Polyester and the Ariel Conundrum
So, pleez don't take what I say here as (attempted) squeezing of Mr Terry Alsberg.
His talk was given 28 years ago, and is much more tech than what I have mind for.
This was a time when vinylester began use as a laminating resin. Terry says,
Vinylester is a "vinyl modified epoxy" (Ebb always assumed that it was an epoxy modified
polyester!) However, Terry says that they were using, instead of vinylester, an "acrylic
modified epoxy". I'm chemical illiterate, except for xperiences I've had with certain resins.
'Acrylic modified epoxy' is a vinylester resin, it is a polyester blend, NOT in any way epoxy.
The distinction between epoxy and polyester is very important.
The 'peel-resistant-strength' of glass laminations made with epoxy is 'five times' that of
polyester. This is as Terry quotes a US Navy 'boil' test result during his presentation.
I'll take that as an average, as there are many forms of glass fabrics, and other materials
like Kevlar and carbon fiber. All these fibers are very smooth, non porous, unlikely
filaments to be glued by any resin. I have found (usually by mistake) that it is very easy
to take a wood chisel and delaminate A-338's original polyester composite - and almost as
easy to peel epoxy lay-ups. Resin does not get absorbed by these fabrics, no matter how
they are constructed - most we can expect is that they are surrounded or encapsulated:
mat, S-glass, X-mat, roving, woven or knitted single fabrics. The chisel 'follows' the
impregnated fabric which has 'less' resin, less resistance. Matt gets most amalgamated.
BUT the chisel may also 'follow' a cold joint, where tabbing, eg, was added after cure.
Shift from shear resistance to another attribute of epoxy. Terry (probably referring to a
slide in his illustrated talk) says US Navy tests have confirmed that the 'strength retention'
of a "modified epoxy boat will be at 93.3% of its original strength after aging, and polyester
dropped to 41.9% of its strength, and this is why some hulls go soft after a while, they
don't hold headstay tension anymore. {This is scary viz Ariel/Commander polyester.}
"The reason why they oil-can more going through water is because as the resin ages, it's
lower in strength. Another thing that happens as the resin ages, it tends to be a little more
brittle and so it cracks and you can see little microscopic cracks through it. Those little
microscopic cracks also mean more oil-canning and less headstay tension, less shroud
tension, all those sorts of things...." 'Oil-can' aging can be the result of poor engineering.
Or the result of using epoxy specs for boats using polyester blend resin composite.
Polyester resin oil-canning will age crack. Oil-canning epoxy resin will not crack, just flex.
If they built Espresso 27s with 'acrylic modified epoxy', then all Terry's brouhaha is BS!
Years ago, tried to find info on the time aging (rather than work aging) of early polyester.
Found a gov report of Navy tests on some maturing barges they had (WWII,50s,60s?)
-- they seemed unchanged, ageless.
Terry quotes Navy tests, comparing polyester and epoxy, from a time later than the 60s.
We know that epoxy gets eaten by UV - unless protected, it will rapidly decompose. But
polyester from the 60s?....SO FAR, it's only the gelcoat we ever hear about!
OK, so Terry isn't talking about Pearson Ariel/Commander isophthalic polyester of two
decades before, is he? Really, he is probably referring to the blister-prone orthophthalic
hulls of the mid '70s. He's talking in 1987. And he's talking about engineered boats.
And comparing with his Carl Schumacher, N.A. designed Express 27. "of course we hope
that the boats will last at least 25 years.* They were engineered and designed to do so."
Hope if or when LittleGull takes a glancing blow from the butt of a log 200 miles offshore,
that the peel resistance of my 50 year old sweetie.... will be as good as new!
'Modern engineered resins' and the boats made from them - along with 'oriented strand
S-glass' - versus Pearson's oriented strand woven roving and lots of scramble strand matt
....coupled with non-compromised, pre 1973 oil embargo, non modified polyester laminated
by farmers from the Azores...(more than 6degrees of separation there!)
The Pearson cousins mast have talked about it, never recording what was said - but what
was the expected life of our Ariel and Commander? Were they 'engineered and designed
to last 25 years' ??
The wish-I-was-epoxy sloops of the 80s have probably fallen apart*. But our indestructable
little racer-cruisers of the 60s, with authentic polyester and plain glass, keep going on,
hopefully on-going. LittleGull's Biological age is way younger than her Chronological!
Realize Terry's talk is kept posted to celebrate the Express 27's designer's and builder's
genius and expertise. Our proto-engineered A/C hulls are now twice the age of the
projected life of Express 27, now 28 years or so since first produced. Are they still around?
Or have they shattered like an engineered sugar cube? Bet these boats were trouble.*
When I sit or walk close to the hull of LittleGull...... what is that tiny tinkling I hear....?
(the crack of doom)
*The Express 27 is a viable modern-day racing class association sailing machine.
Conceived as a legs over the rail sport boat - with a pleasant sit-down interior
with just '150# of furniture'. One was driven to Hawaii, and while logging 1100
miles, averaged 16knots in a four day run. Only similarity with a Pearson A/C
is a ballast/ displacement ratio of nearly 50%, a straight sheer, 8' beam and a
balsa core deck. 117 built in SantaCruz, most race on SanFranciscoBay. Sail
mark is a circle with a line thru it.... Obviously they haven't fallen apart, yet.
OK, so you really want to know more about polyester problems? Here's a no-blister-
barred take, by whom else: Pascoe! He shows you 'How cheap can we make yer boat!'
The Wonderful World of Hull Blistering And Other Interesting Scams
google: Boat Hull Blisters: Blister Again? Yacht Surveyor Online
www.yachtsurvey.com/moreonblisters.html.htm
