Adding Setscrews to Stanchion Bases
Hi guys,
I'd like to modify my original stanchion bases by adding 2 setscrews each so I can remove the stanchions and lifeilines without having to remove the bases for winter tarping. They are currently all off the boat and in the basement, so now is the time to do it.
Is it even possible without a drill press? I assume I'll need a special drill bit for drilling stainless? Should I drill them opposite each other? Do I need more than one setscrew for each stanchion? How about just tapping the existing hole that goes all the way through the base and tube, then just add another hole to the base that doesn't penetrate the tubing? Would this be more secure than drilling 2 hole into the tubing? And - how do you tap the new holes?
Any "how to's", advice, and ideas welcome.
