Ebb obviously the Ariel toe rail and the Commander toe rail are quite differant
The PO of Destiny had drilled a couple of holes in her deck to allow the water to drain out that Kyle is talking about. See the picture below and please excuse the dust that has accumulated on Destiny's deck since I've been working only on the inside.
Kyle
I plan to do exactly what you are suggesting except I will plumb my scupper drain into the bilge pump drain line because Destiny will have dry storage in the laz after the inboard electric drive is installed. The link below is to one version of the drain (not necessarily the one one I will use) that could work as long as it is recessed per your drawing.
http://www.jamestowndistributors.com...+Scupper+Drain
