inner stay by Alberg on Commander?
Hey TONY, look at this!!!
On page 109 in our Manual is a plan and profile view of the interior of a Commander....
In the upper right of the page is a small sail plan with a few notations, hard to read....
There on the sail plan for all intents and purposes is an INNER STAY drawn in dotted lines.
It may be that it represents some figuring of areas
as there is a unusual triangle of dotted lines with the notation "100% foretriangle" underneath the number 150...that supports that interpretation
and what looks like a center of effort symbol.
It appears to be figuring for the addition of a PARALLEL INNER STAY.
BUT the dotted line inner stay
because that is what it looks like,
is just where you expect a modern babystay to be on an A/C. About 3' in.
It's parallel to the forestay and closer together than what a cutter would have.
[A guy on a cruiser site thinks that instead of a 150 - which you'd have on the forestay on a furler and loose shape as you furl - be better if a yankee was the foresail and fly a staysail on the inner - both same time.
Rather than thinking of the babystay as a storm alternative.
Parallel forestays SAY double headsails. He was talking of another sloop rigged boat with an added babystay.]
A removable non-parallel solent stay is designed for temporary rigging of a smaller heavy weather sail.
Page 109 is pretty obvious not a working drawing by Alberg.
and could be notated by anyone and put there at any time before it became part of the Manual....
As a coincidence you gotta admit it is pretty wild.
Wasn't it said once that you couldn't sneak anything past Alberg as a designer?
An inner stay is not something you'd have on a small daysailor in the 60s....
And he wouldn't be figuring out the CE of a fractional rig. Right?
IT LOOKS LIKE A DOODLE FOR A DOUBLE HEADSTAY RIG ON A COMMANDER.
Yes it does!
Tony, anybody, care to venture a guess what's going on here?
__________________________________________________ ____________________________________
In the Cape Dory line of the early '80s Alberg introduced short bowsprits and doublehead rigs. The inner stay is shown in brochures with a jib on a club. The cutter rig appears on larger yachts. My impression is that the mast position was not moved. But of course the main could be placed anywhere on the Cape Dory coach roof. Larger yachts were also available as ketches.
In the Cape Dory literature there are no obvious runners rigged to offset the lower head stay....
