Challenge DURABAK to come clean. They played the Good Old Boat card.
I have no experience with this polyurethane coating.
Whatever actual experience garnered from the googler is of no use.
For Duraback there are thousands of pickup bed liners being BSed about, but really none is able to express themselves or even be experienceably credible.
The Durabak company (and I remember, the Santitred company) develop a kind of HYPE MUSIC in talking about their product. They get into it like a shill with a hook and don't let go! Because the stuff is way over-priced. NONE of it seems to be based on actual applications. There is a paucity of application photos - even those where they are painting concrete intersections or institutional hallways. Their whole sleight of mind is to rig a davit over your checkbook and pluck your bucks, mon.
We may be dealing with a solvent-based company here - in my book they may have lost it due to 'ene chemicals.* Or their product really cannot make the cross over into the reality of the DIY work-a-weekend world. All live experience expressed on the net seems to be reduced to base testosteronic dim boggy wit. Tho I admit when I'm looking for info I have no patience. To be fair, I think Sanitred is water-base. That's good but it's still too picky for a boat yard.
Ah done know, Craig.... Hardass E-poxy and beach sand is the way to go.
It's important WHICH beach you get yer sand from.
Ah ben a lookin for some softer stuff, I figger one day I'll go barefoot til the last breaking wave or the last dead wrong-reckoning, which ever comes first. Looking for soft decks, soft cockpit.
Like Geoff, it's the sand BETWEEN my toes that I ache for.
Polyurethane has a reputation for standing up to chemicals. I've yet to see specifics, altho the manufacturer's BS can get pretty caustic.
Better keep your hydrochloric acid in a safe place along with your dichloromethane. Kidding aside, I think, THINK, that you can spill beer, icecream and gasoline on it without effect.
Any epoxy you use should be coated with something to help preserve it since UV breaks it down. Polyurethane is an excellent choice.
__________________________________________________ ____________________________________________
http://www.cotelind.com/apptips.htm
is 14 pages of 'tips' for simple application of Durabak out of a can. They recommend XYLENE to prep surfaces for coating. Then you read that Metacote might be a good idea to use as a primer on an old frp boat. And here you discover that broadcasting 60 grit SILICONE CARBIDE onto wet Durabak is recommended for wet conditions and extreme slopes, conditions well documented on Ariels and Commanders.
NOWHERE is there a photo accompanied description of a three coat application of the Durabak system to the deck of a sailboat. That could be the answer. It really may be ALL BS
__________________________________________________ ____________________________________________-
*xylene/propylene/butudien/benzene/toluene/ethylene
